i hope this could help someone on usb install problem...
fuchls
ill make this very simple
my setup :
i5 haswell
gigabyte b85 chipset
8gb ddr3
4tb wd red
apacer 8gb usb stick
what i did
1. wrote 9.2.0.1 img on usbstick
2. booted up fine with ip 192.168.1.250
3. in webgui made very basic changes in the General tab, rebooted
4. system boot halted with complaints that config.xml on usbdrive cant be loaded/found
5. imaged again with another software and proceed to reboot back system
6. steps #2-#4 got repeated
7 inserted usbstick in different usb slots, repeatedly got number #4
how i fixed it
1. wrote 9.1.0.1 img on usbstick
5. rebooted several times with various setting change with no problem
6. success
out of my above hardware list i suspect ver 9.2.0.1 doesnt like b85 chipset
can anyone with b85 verify?
Yatti420
Specs please. Could be USB problem could be hardware problem.. Did you do the basic burn in / testing? Including testing USB.. Is it USB3.0..
fuchls
specs on top of my post... but nvm...
for this box im running NAS4free, just realized i posted in the wrong place...
my other boxes running FreeNAS has not run in to problems which cant be fixed yet...
Thank you anyway.. :)
fuchls
just to answer your question, i tested wih all available usb2 an usb3 slots to make sure...
Yatti420
Yes this is not the place for Nas4free.. I'm not sure how you ended up migrating to 9x.. Good luck..
dgkim6200
thanks for a solution!!!!!!!
i were having troubles same as you.
but when i booted 9.1.0.1, it can't find my onboars lan card.
my lan card is Intel I217-V
i think it's because this version dosen't supports mine.
so i'm trying to get older lan card and do 9.1.0.1 with it.
do you think that it could solve the problem?
There is no FreeNAS 9.1.0.1. So either you're confused or you are talking about a different software package altogether.
dgkim6200
actually, i did what you said with nas4free. i didn't worked with freenas.
but also, i think that what you said must be the solution with freenas.
