DrKK
FreeNAS Generalissimo
- Oct 15, 2013
On Services->rsync, you can set the port explicitly. Default is 873. So you could change it, ostensibly.
But then, when you set an rsync task on another remote FreeNAS back to this one, in module mode, there would appear to be no way indicate any special port, should you venture out of 873. Presumably, if you can easily change the port the rsync service listens on, then you ought to just as easily with an explicit option in the GUI set the port it will attempt to phone back on from the other side. But either it does not, or, I'm an idiot. Or both.
Would appreciate being told what I'm missing here.
