calgarychris
 - Aug 27, 2011
I've been reading and reading to try to figure out rsync, but I'm afraid I still don't have it. My situation is that I have a large photo collection on a DNS-323 with ffp installed, as well as a FreeNAS server that I want to use to back up the DNS. I'm confused on how to set up rsync to get this working between the two and the example in the docs is clear but written for two FreeNAS systems.
I guess I'm looking for confirmation that my understanding is correct:
1. I believe I want to use the FreeNAS system as the server and the other as the client
2. I don't need to set up an rsync task as I will do this on the non-FreeNAS system
3. I need to set the rsync module under Services->Rsync Modules->Add Rsync module
4. I need to turn on the service
5. I will need to somehow create a "task" on the client system using rsyncd.conf?
6. Presumably the name in 5 above will need to match the module name?
7. I set it to run via cron on the client system (no idea how to set that up)
8. I don't believe I need ssh as this is for a small home network, but I will limit access via the hosts allow option - any significant advantage to using ssh in this scenario?
Does the above make sense? Am I missing anything? Am I totally off the mark? I think it's the setup of the client system that I am most confused with (wish I could just get two FreeNAS systems!).
Any help or tips greatly appreciated
Cheers
Chris
Cheers
Chris
