I feel really dumb
Heracles
Neophyte Sage
The hardware may be defective... The monitor, the graphical adapter, the cable, ...
You need to test your hardware from other known to be working pieces.
ThreeDee
Senior Member
if you have another DDR3L SODIMM module you could use to test with .. could be bad memory .. or bad PSU ..etc .. as stated by Heracles above
Netdewt
Member
It's a brand new stick of Crucial. I just can't imagine. But I'll dig up another stick. Monitor and cable are good.
c77dk
Member
Some Supermicro boards can be _really_ picky - had a similar issue with a blade using DDR2 RAM (had to get more into the system after DDR3 had been the norm for a while), and my supplier got some ram with the right timings and all - the blade just wouldn't start at all, until we found some from the HCL.
Netdewt
Member
I'm worried that this is the case, but there is NO availability on their "approved" RAM, so I just picked something generally trustworthy.
c77dk
Member
Netdewt
Member
Unfortunately not. I didn't know they had that tool.
The one I got is CT8G3S186DM.
ThreeDee
Senior Member
keyword .. "should" work ..
Is your current stick DDR3L? ..meaning .. it can run at 1.35v instead of 1.5v?
Patrick M. Hausen
Dedicated Sage
If a mainboard does not come up with a picture on the monitor at all, IMHO the most important thing is to have a speaker connected to the corresponding pins. The number of beeps tells you what is wrong. The details are in the mainboard manual.
Netdewt
Member
Thanks, I ordered a speaker. The only messages shown in the Manual are RAM problems basically.
Netdewt
Member
Supermicro says it's the RAM. They want me to find one of these 2 part numbers. I've never heard of RAM selection being picky...
MEM-DR380L-IL02-SO18
MEM-DR380L-IL03-SO18
I found these from Nemix, then he said that's no good. Has to be from Innodisk, which I can't find anywhere.
c77dk
Member
If you can, then buy direct from Crucial - according to the page they guarantee it will work.
Netdewt
Member
They are out of stock. I'm sick of waiting, so I'll pick up Crucial from Micro Center nearby.
Netdewt
Member
New RAM works!
Now to figure out the actual install. So far it just boots to the installer, then restarts, and again, in a cycle.
Patrick M. Hausen
Dedicated Sage
Look for a "watchdog" in the BIOS settings, then disable it.
Netdewt
Member
I found that, it was disabled. I tried changing another setting about restarting after power loss. Now I can't get it to go to the install screen at all. I'll try again tonight.
I suppose it's possible that this motherboard is not compatible with TrueNAS, considering all the other issues I've had so far. I might just run Linux something and use the onboard RAID 10 controller.
Patrick M. Hausen
Dedicated Sage
Some Supermicro systems have an additional jumper on the MB for that if I remember correctly ...
