Any reason FreeNAS ( 9.2.1 64bit) installs using a MBR sheme, while FreeBSD uses GPT ?
Reason for asking, is the installation of the hyper-v integration components package on a Freenas vm
This setup fails because the package checks for gptid's which of course are non-existing in case of MBR.
Installing Freenas on a vhd(x) already initialized with GPT terminates without warnings,
but (setup demanded) reboot isn't too happy :
However the IC install on a virtual FreeBSD(or Debian, with the Linux IC obviously) plays nice ..
FreeBSD installer also allows you to go to the shell during setup, having that option could be a workarround.
Create the GPT and copy the install image onto the boot partition , which I suppose is what the FreeNAS install does anyway.
The IC is needed for pass-through of a physical disk, which works as advertised with virtual FreeBSD + IC
'Bref', my question : how does one install FreeNAS using GPT ?
( if this a real stupid question, , I'm very new to the unix universe, but i did some homework , search "GPT" results all seemed related to zfs pools or improper hardware )
Help would be much appreciated , and no doubt give you a warm fuzzy glow .
Supermicro X10SAE / xeon E3-1265L : hardware ( VT-d ) should be fine
GEOM: da0: the primary GPT table is corrupt or invalid. GEOM: da0: using the secondary instead -- recovery strongly advised.
