Evening All,
I'm new to FreeNAS and I'm looking to set up small temporary trial installation in a VM just to test it out on my home server. This is purely for testing so I can play with the O/S and start to learn it - I'm planning on creating a few 1GB virtual disks for the FreeNAS VM just to play around a bit. There will be no essential data, and very little data in total (probably some pictures, files, and videos), just to test it all out.
My server is a TS-140 running Hyper-V Server 2016 with 16GB ECC RAM, and my question is: are there any particular settings / tweaks I need to do to the VM or the hypervisor to get it working well enough with FreeNAS to trial it out?
I've read through a lot of the forum and know that Hyper-V isn't necessarily the best hypervisor for FreeNAS (and that virtualizing FreeNAS isn't great unless you can pass-through an HBA), but it's what I'm currently running at home on my server. My hyper-v server has a WHS 2011 VM in it, which I'm hoping to migrate the data to FreeNAS if I can get to grips with it, as well as a couple of windows 10 VMs that I use for messing around in.
Grateful for any tips / pointers! TIA.
