Yatti420
- Aug 12, 2012
How To Use Transmission Remote
In case anybody wanted to manage a second transmission installation remotely (2 freenas boxes for example) you can use transmission-remote included with the Transmission pbi's to access the remote installation.. It's easy to do via ssh..
Access the remote installation's transmission jail (jexec # /bin/csh) and run the folowing "transmission-remote" for an overview of commands..
If you have a transmission password you will be required to authenticate (all lower letter) in order to successfully send commands..
"transmission-remote -n user:secretpassword -si" will list session info as shown below..
"transmission-remote -n user:secretpassword-l" will authenticate and list all torrents (with IDs) loaded into the remote transmission daemon..
If you have 3 torrents loaded and wish to remove them all from the list you would run "transmission-remote -n user:secretpassword -t 1-3 -r" (This doesn't remove data - equivalent to "remove from list" in GUI)
"transmission-daemon" will allow you to set daemon settings if applicable..
See ya
Yatti420
VERSION Daemon version: 2.77 (14031) RPC version: 14 RPC minimum version: 1 CONFIG Configuration directory: /usr/pbi/transmission-i386/etc/transmission/home Download directory: /tmp Download directory free space: 150.6 GB Listenport: 51444 Portforwarding enabled: Yes uTP enabled: Yes Distributed hash table enabled: Yes Local peer discovery enabled: No Peer exchange allowed: Yes Encryption: required Maximum memory cache size: 4.00 MiB LIMITS Peer limit: 300 Default seed ratio limit: 0.01 Upload speed limit: 50 kB/s (Enabled limit: 60 kB/s; Enabled turtle limit: 50 kB/s) Download speed limit: 750 kB/s (Disabled limit: 100 kB/s; Enabled turtle limit: 750 kB/s) MISC Autostart added torrents: Yes Delete automatically added torrents: No
See ya
Yatti420
