how to set warning temperatures individually per drive
blckhm
I have many nvme ssd's in chasis for l2arc and zil logs stuff and also spin drives for pools. Now I need to change warning temperatures levels because my nvme drives runs near 42°C and smart always throws an error like that "Device: /dev/nvme0, Temperature 41 Celsius reached critical limit of 41 Celsius (Min/Max 33/48)."
I dont want to raise warning levels for all my drives because I want to keep all attention on spin drives and upper levels of 41 Celcius is critical for these traditional drives.
Is there any possible solution to make this warning levels to set individually per drive? especially for nvme drives?
thanks
Alecmascot
You can set the individual temperature settings per drive.
Go to the drives via "Storage".
Just to expand on that, it's to fill in the Critical, Difference and Informational fields like you would on the S.M.A.R.T. service, but customized for that drive only.
blckhm
oh, great! thanks a lot.
