Got a quick question, by looking at the Web GUI, I see how you can set VLAN interface where you assign the parent interface, VLAN tag, IP, etc. However, here is kind of a chicken or the egg question. Let say I have VLAN 200 and 201, and I am setting this on a brand new physical interface, and neither of that VLAN are set to default on the physical switch port. So which method do I use?
1. I start with the parent interface, set an IP and first VLAN tag, then add a VLAN interface on top of the parent interface, with another IP and the second VLAN tag
or
2. I start without touching the parent interface (no IP, no VLAN tag), I start with my first VLAN interface, add IP and VLAN tags, Than I add my second VLAN interface, add IP and the 2nd VLAN tag
dwc
or
dwc
