Peppo
- Jun 20, 2017
Hello
I would like to restrict the home directories which I export through AFP to specific groups.
For normal AFP shares you can configure this in "Allow List". But for the home directories, which you configure in "Services -> AFP" there's only an option to set "global auxiliary parameters", "volume parameters" are not configurable.
Adding the configuration by hand in /etc/local/afp.conf works perfectly fine, e.g.
But setting this by hand is not an option, since every time you add or change a share, you loose that change.
Is anybody aware of how you can restrict the homes to certain groups?
Thanks -- Peppo
[Homes] basedir regex = /mnt/raid0/home time machine = yes valid users = @my-group
Thanks -- Peppo
