how to login qbittorrent webui?
aurensia
after I install plugin qbittorrent, go to webui and id admin/ pw adminadmin I can`t login webui.
It just Installed and I don`t adjust setting.
I install this plugin freenas webui -> plugins -> install
  • Like
Reactions: Syx
Syx
You could read this post:
If you'd prefer to watch a video guide here is the solution: https://youtu.be/-8zVxX7Jf4I
Thanks for this Reddit link. This thread was the top Google result for my issue.
I have just installed qBitorrent via DockSTARTer - so no popup - and the solution was to check the container logs (which I did via Portainer). There was a line in there:
The WebUI administrator username is: admin
The WebUI administrator password was not set. A temporary password is provided for this session: 3MBeEfsNe
After logging in I then went to Tools -> Options - Web UI and changed the username and password under Authentication.
