QBittorrent webui won't load
Steven SL
FreeNAS-11.2-RELEASE-U1 / Dell R310
QBittorrent is installed. It works once right after install (DHCP), but stopping / restarting it causes the webui to stop working. Uninstalling / reinstalling - pretty much the same result - works once on DHCP, and start/stop breaks the UI. Setting a static IP doesn't work at all (IP does not reply). When on DHCP, the IP does reply.
How do I go about diagnosing this - what logs should I share?
thank you
D
dlavigne
Guest
Hardware specs?
Full output of ifconfig within code tags.
Anything in /var/log/messages when it's not working?
Steven SL
Dell R310, 24 GB RAM, 4x 2TB SATA with controller H310 (IT Mode). Chipset is Intel 3420, video card is Matrox G200eW, Intel(R) Xeon(R) CPU E5-2407 0 @ 2.20GHz (4 cores) .
ifconfig:
bge0: flags=8943<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500
        options=c0099<RXCSUM,VLAN_MTU,VLAN_HWTAGGING,VLAN_HWCSUM,VLAN_HWTSO,LINKSTATE>
        ether f0:1f:af:dc:bd:c6
        hwaddr f0:1f:af:dc:bd:c6
        inet 172.30.0.20 netmask 0xffffff00 broadcast 172.30.0.255
        media: Ethernet autoselect (1000baseT <full-duplex>)
        status: active
bge1: flags=8802<BROADCAST,SIMPLEX,MULTICAST> metric 0 mtu 1500
        options=c019b<RXCSUM,TXCSUM,VLAN_MTU,VLAN_HWTAGGING,VLAN_HWCSUM,TSO4,VLAN_HWTSO,LINKSTATE>
        ether f0:1f:af:dc:bd:c7
        hwaddr f0:1f:af:dc:bd:c7
        options=600003<RXCSUM,TXCSUM,RXCSUM_IPV6,TXCSUM_IPV6>
        inet6 ::1 prefixlen 128
        inet6 fe80::1%lo0 prefixlen 64 scopeid 0x3
        groups: lo
        ether 02:e6:7c:7e:8a:00
        nd6 options=1<PERFORMNUD>
        groups: bridge
        member: vnet0:6 flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP>
                ifmaxaddr 0 port 6 priority 128 path cost 2000
        member: tap0 flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP>
                ifmaxaddr 0 port 5 priority 128 path cost 2000000
        member: bge0 flags=143<LEARNING,DISCOVER,AUTOEDGE,AUTOPTP>
                ifmaxaddr 0 port 1 priority 128 path cost 20000
tap0: flags=8943<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500
        options=80000<LINKSTATE>
        ether 00:bd:03:27:a4:00
        hwaddr 00:bd:03:27:a4:00
        status: active
        groups: tap
        Opened by PID 90693
vnet0:6: flags=8943<UP,BROADCAST,RUNNING,PROMISC,SIMPLEX,MULTICAST> metric 0 mtu 1500
        description: associated with jail: qbittorrent
        options=8<VLAN_MTU>
        ether 02:ff:60:5b:ca:e5
        hwaddr 02:1d:d0:00:06:0a
        status: active
        groups: epair
Nothing unusual in /var/log/messages. I will uninstall, reinstall, stop/start and see if anything interesting appears
Steven SL
Did that resolve the issue?
No - its not limited to QBittorrent it seems. No amount of installing, uninstalling - DHCP or static seems to be consistent. I will spend some time on that tonight, to gather some useful logging information.
