[How To] Install Subsonic 4.8 on FreeNAS 9.1.1
thorndike
May I suggest putting the step that required UNCHECKING the VANILLA setting in BOLD? Unfortunately, I had to recreate my subsonic jail and forgot that very important step. Now I have to rebuild and recompile....argh!
Stab
Hi !
First of all thanks for this great tutorial, I followed it and it works like a charm.
However I have a little problem, the autostart function is not working, I can launch subsonic by typing "jexec 1 /usr/local/etc/rc.d/subsonic start" in a shell but it doesn't launch at startup.
I created the file " /usr/local/etc/rc.d/subsonic", i made it executable and added
  1. # subsonic start up
  2. subsonic_enable="YES"
  3. subsonic_user="sonic"
  4. subsonic_bin="/home/sonic/subsonic/standalone/subsonic.sh"
in "/etc/rc.conf"
Any ideas ?
anika200
Hi !
in "/etc/rc.conf"
Any ideas ?
Did you double check all your path statements in those files?
What are your perrmision and owner of /usr/local/etc/rc.d/subsonic?
% ls -al /usr/local/etc/rc.d/subsonic
Have you looked at dmesg for errors, do you get any errors when you try as per
To test it out you can locate the subsonic process with Top and kill it, then issue the above command and it should start subsonic and give you the pid of the process.
Lastly, check out the rc debug tool.
Stab
Thanks for your quick answer.
Yes the paths are valids, I used the same folders as in your tutorial.
I can lauch subsonic as "root" or as "sonic" with "/usr/local/etc/rc.d/subsonic start" without any problem, it's just the startup script that doesn't works with me
Here's the result of "ls -al /usr/local/etc/rc.d/subsonic" :
-rwxr-xr--  1 root  wheel  720 Nov  3 16:11 /usr/local/etc/rc.d/subsonic
Nothing in dmesg, I checked with rc debug, but I do not see anything about subsonic in /var/logs/messages
One more question, should I change this in "/usr/local/etc/rc.d/subsonic"
: ${subsonic_enable="NO"}
: ${subsonic_user="root"}
: ${subsonic_bin="/usr/local/sbin/subsonic.sh"}
EDIT : It's seems that it's working now using this startup script :
    #!/bin/sh
    # PROVIDE: subsonic
    # REQUIRE: LOGIN
    # KEYWORD: shutdown
    # Add the following lines to /etc/rc.conf.local or /etc/rc.conf
    # to enable this service:
    # subsonic_enable (bool):  Set to NO by default.
    #            Set it to YES to enable it.
    . /etc/rc.subr
    name="subsonic"
    rcvar=${name}_enable
    subsonic_enable=${subsonic_enable-"NO"}
    pidfile="/var/run/${name}.pid"
    procname="/usr/local/openjdk7/bin/java"
    start_cmd="subsonic_start"
    start_precmd="rm -f $pidfile"
    stop_postcmd=$start_precmd
    subsonic_start()
      echo "Starting Subsonic"
      export PATH=$PATH:/sbin:/bin:/usr/sbin:/usr/bin:/usr/games:/usr/local/sbin:/usr/local/bin:/root/bin
      cd /home/sonic/subsonic/standalone
      sh subsonic.sh
    load_rc_config $name
    run_rc_command "$1"
I found it here : http://forum.madsonic.org/viewtopic.php?t=475&p=817
anika200
@Stab
Just out of curiosity can you ssh into your subsonic user jail as a regular user and post the output of:
echo $PATH
Stab
Here you go :
$    echo $PATH
anika200
Here you go :
$    echo $PATH
yea, thats the path if you run the command as root. I wanted a different command run but I got to see what I wanted anyway. Thanks.
anika200
Updated 11/21 with a new more readable/follow-able format. Any feedback is always welcome, however it may take some time to sink in.;)
underpickled
So now that there's a new beta out... I've been nervous about trying to upgrade to 4.9beta1 at the risk of messing something up. Do you know if just subsonic.jar needs to be replaced in the subsonic directory or is there more of a process?
anika200
I have been reading a few things about it and do not think it will be a big problem. However, I am going to wait for the real deal 4.9 before I start messing around, things are working pretty good.:)
If you try it let me know what happens please.
I am thinking about doing the whole war file when the new version comes out depending on their upgrade path.
underpickled
I was thinking the same thing (leave it alone until 4.9 drops). Since beta2 just came out, it might be getting close. I'm reluctant to go back in and set up my subsonic config file again if I don't have to... I'm hoping I can upgrade by replacing everything except the config file.
Ngjtt
I forgot to check the lame checkbox after the make command. (stupid of my I tried to select with enter) can anyone tell me how to do this afterwards?
anika200
Try "make config" and see if it presents you with the options again. To be clear, you will have to compile it over again starting with the command "make config".
Ngjtt
That worked thanks. make config gave me the options back, afterwards had to give the make command to execute the changes made
anika200
Please click the like button if you find this useful, it keeps me motivated and lets me know how useful this post was to users. Thanks
Update: 12/12/2013
They renamed some ports and also added ffmpeg 2 :cool: to the ports tree. I have made a small change to the instructions and am compiling it now to see how it works. --- Tested and is working good streaming to my linux box. You can check what version you are using with
# ffmpeg --version
To upgrade to ffmpeg 2.x
log into your sonic jail as root user and run
# portsnap fetch update
this will take a little while. When that is done
# cd /usr/ports/multimedia/ffmpeg
# make
Make sure the LAME section is checked and AAC if you want it.
# make install clean
When that is done we want to remove the old link in subsonic folder and create another one for the new ffmpeg version
# rm /home/sonic/subsonic/transcode/ffmpeg
# ln /usr/local/bin/ffmpeg /home/sonic/subsonic/transcode/ffmpeg
Verify your new link is owned by your regular user and not root
ls -l /home/sonic/subsonic/transcode/ffmpeg
That is it, we can now take advantage of all the new version 2 features and bug fixes.
Update 2:
It appears that the configure step already has Lame support turned on.:) This is great news because we should just be able to use pkg to install ffmpeg instead of compiling from scratch.
It does not appear to be packaged yet so that will have to wait.
underpickled
Update: 12/12/2013
[omitted for length]
Update 2:
I'll hold off on this until I've successfully upgraded to 4.9. After seeing the changelog for beta 3, I'm pretty excited. If you decide to upgrade when the final release is out, I'll be very happy if you make a post on the upgrade process :)
anika200
Looks like Freenas 9.2 and Subsonic 4.9 might be coming together all at the same time, should be interesting. :D I do plan on updating the thread or possibly starting a new one for FN9.2 if things get complicated.
di0de
Sorry if the question has been answered, I skimmed this thread but didn't see it addressed. Is it completely necessary to create a new dataset for music/media? I already have tons of music in several different folders on my NAS, can I just use what I already have?
Thanks.
anika200
Thanks.
You can use any dataset you want, the guide just demonstrates how to do it for people that do not already have one.
