I am trying "scale" as alternative for "core". Especially in area of jails/vm's/apps. The problem I am facing is, that vm's, jails and applications, only work
as long as you do not use vlans ...... and do not want to use "localy defined static IP-addresses (IPV4 & IPV6)".
So today a played around a bit with apps.
- I defined a trunk
- with a couple of vlans
- each connected to their own bridge
My intention is to connect such a vlan related bridge with one or more apps
and other apps with another bridge.
I also defined some storage datasets for the apps and did start to define two test apps (nextcloud and plex), expecting that I could connect an app to a bridge and to assign IP-addresses.
Not so ...... and if so ....... it does not work .....
I noticed that there is settings => advance settings .... in the app screen where you can in a limited way define some settings which I had expected with each app!!
However, the settings are generic , so at best I can choose ..... if I change the settings to what I like for app-A of those for app-B .....
That is absolutely not what I had in mind!
Is there any way to link apps to the IP-addresses you have in mind for each particular app.
and if so how (preferable via a GUI!) !!??
- I defined a trunk
