Hello! I need someone to explain some basics, or point me in the right direction.
Tried the plex(pass) app yesterday and learned (from the internet) that apps do not know about NICs?
I have set up one 1G NIC (.11) for TNGUI and made a bidge "br0" (.13) which has a physical member (sfp+). VMs and shares are all on br0, awesome. VMs get IPs whenever they appear (DHCP), even nested VMs get IPs. But not apps...
The plex app defaulted to br0, I think, since the plex web interface is available on br0's IP: ".13:32400".
I found the app settings tab, where I can select which NIC to use. If I had more than one app, would all apps move to the selected NIC and get a new IP if I where to change this setting? Is it possible to assign different NICs to each app?
My old plex instance lives on .4 using the old plugin. In pfSense plex has has .4 reserved, and there is a firewall rule to open port 32400 for access to plex, pointing at .4. Are there any security implications if I point this to .13:32400 compared to a separate IP altogether?
