sapster77
- Mar 17, 2022
TrueNAS scale 22.02.0.
In order to be able to mount a samba share on a VM, I created a bridge so the VM guest could see the host.
Used this guide:
https://www.truenas.com/community/threads/vms-cant-see-host.88517/
which worked fine (VMs can see host). So now I have a bridge (br0) with a static IP 192.168.1.25 and a enp1s0 as a member of the bridge.
I seems this fixed the issue with the VMs but has killed the network connection for K3s (apps are not running) and truecharts cannot access the catalogs. My openvpn server has also failed as I can no longer access it from outside my LAN (OK from inside). So it's probably some forwarding issue.
Tried this, but this is not absolutely not my strong side, and had no effect.
iptables -A FORWARD -i br0 -o enp1s0 -j ACCEPT
iptables -A FORWARD -i enp1s0 -o br0 -m state --state ESTABLISHED,RELATED \
-j ACCEPT
iptables -t nat -A POSTROUTING -o br0 -j MASQUERADE
All ideas and help are very much appreciated. Thank you,
Used this guide:
-j ACCEPT
