how do I configure xdebug into sublime text 3
DavidGo43
So far I managed to configure xdebug in php and I type the command like pkg install php-xdebug and in that php.ini I have to add the
xdebug.profiler_enable = 1
xdebug.profiler_output_dir = /tmp/profiler
xdebug.remote_enable=On
xdebug.remote_host="localhost"
xdebug.remote_port=9000
xdebug.remote_handler="dbgp"
xdebug.remote_autostart=1
then I restart the apache and then when I load my info.php page it contains the xdebug page that like this in that picture. After that then I follow the instruction on that link http://markonphp.com/debugging-xdebug-sublime-text-3/ for how install xdebug for sublime text 3. I install package for sublime text 3 and select xdebug client to install. After that then created a project folder called awesome.sublime-project and made into a new file. In that new file I created
"folders":
"follow_symlinks": true,
"path": "."
"settings": {
"xdebug": {
"url": "http://myipaddress",
"path_mapping": {"//davidjonesfolder/davedataset/daveserver/usr/local/www/apache24/data/awesome" :
"{"//davidjonesfolder/davedataset/daveserver/usr/local/www/apache24/data/awesome"}
I already got my jail to work for my php file but when I tried to debug hello.php it didn't work at all.
