I just installed the official Home-assistant app (with "host network" enabled) and I'm getting the following error:
According with this post TrueNas APP version of Home Assistant zeroconf error the solution is to disable the mDNS option in scale networking advanced options.
However, i kind of remember that mDNS was needed for the discovery of trueNAS as a target for timemachine backups by MAC users.
This post seems to confirm that fact Hombridge mDNS Problem TrueNAS Scale / Time Machine
In that post they are dealing with Homebridge but the problem seems to be similar. Their solution was to assign a dedicated IP to that app.
But there are 2 problems with that:
It seems that Home-assistant needs to use mDNS internally for zeroconf and so does the truenas scale for timemachine. And because they are both sharing the same IP this creates a conflict resulting in the zeroconf error I'm seeing in home-assistant.
Has anybody else seen this behavior?
If so, how have you been able to solve it?
Do you have any pointers on things to try that may fix this conflict?
Unable to set up dependencies of 'default_config'. Setup failed for dependencies: zeroconf
"According with this post TrueNas APP version of Home Assistant zeroconf error the solution is to disable the mDNS option in scale networking advanced options.
- Home-assistant wouldn't be using "host network" which, per my understanding, is needed for the discovery of devices on the same network.
- And this is the most important one, the official Home-assistant app doesn't have the options to assign a dedicated IP or network interfaces to this APP. It only has "port" and "enable host network"
