I am running Home Assistant app on my TrueNAS SCALE install, and trying to get Homekit to work. It seems like my Home Assistant is running on a different IP Address range, my router uses 10.1.14.x whereas Home Assistant seems to be getting a 172.16.0.x IP address. Homekit requires Home Assistant and the apple device to be running on the same network to work.
I previously ran a Docker for Home Assistant on a Synology and used the "Use same network as Docker Host" option which worked great.
Is there an equivalent "Use same network as Docker Host" option in the TrueNAS app?
