luctins
- Sep 28, 2023
I currently have a server running TrueNAS as the main node for all my applications, hosted on it as native TrueNAS applications or as the external-service chart on other hosts, via traefik.
Does anyone know a 'supported' way of adding a route to traefik with the sticky label enabled?
I'm currently trying to set up mattermost on a separate host from my TrueNAS, and mapping 'chat.my.domain' to it, but it fails to connect the required websocket. After digging around for a while, it seems like i'm missing enabling 'sticky mode' on the websocket path (on my case the path was
This discussion on the traefik forum indicates how to do it using kubernetes labels: https://community.traefik.io/t/traefik-ingress-controller-sticky-sessions/12829
But I'm not sure how to apply them on the 'external-application' chart. Is there any way to do this officially or otherwise?
I'm running TrueNAS-SCALE-22.12.3.3 with Truecharts enabled.
/api/v[0-9]+/websocket
).This discussion on the traefik forum indicates how to do it using kubernetes labels: https://community.traefik.io/t/traefik-ingress-controller-sticky-sessions/12829
