pix
- Mar 11, 2014
Hello I am on FreeNAS 9.2.1 RELEASE x64 still. I have had no issues for months since I built my system.
However today I discovered that I could not get plugin info (installed or available just showed NO ENTRY FOUND)
Turns out I could not ping www.google.com from my FreeNAS box. So I changed the interface setting to DHCP (it had a static) and shutdown my server from the SHUTDOWN button on the webgui.
Now when I press the power button on my server I get the ASROCK splashscreen and
then the usual freeBSD boot screen and then it just keeps putting out the hashtags. I currently have about 20 lines of hashtags.
You get the picture. This is still going on 20 minutes later. My case shows no HDD activity during this and only shows HDD activity when I do a full shutdown and power on and it immediately goes to the load screen.
Here is my build.
Does anyone have any idea what's going on? I keep track of any changes I make on servers as a habit (it's my job) so as stated above - the only change I made was to check off the DHCP box on interface IGB0 so it would pull from the router and then I pressed the SHUTDOWN button on the WebGUI. Waited a few minutes then logged into the IPMI GUI and powered on the server from there.
Any help is greatly appreciated.
F1 FreeBSD F2 FreeBSD F6 PXE Boot: F2 ############################################# ###################################################### ###################################################### ###################################################### ######################################################
Here is my build.
CASE: Fractal Arcmini R2 HDD: 6x2TB WD GREENS. RaidZ2. 7.1TB usable. CPU: Intel Pentium G3220 RAM: Crucial 16GB (2 x 8GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) ECC Unbuffered Server Memory Model CT2KIT102472BD160B PSU: SeaSonic SSR-360GP 360W ATX12V v2.31 80 PLUS GOLD Certified Active PFC Power Supply New 4th Gen CPU Certified Haswell Ready Motherboard: ASRock E3C226D2I Mini ITX Server Motherboard LGA 1150 Intel C226 DDR3 1600/1333
