SOLVED Help Double checking SMART results after getting CKSUM error on Drive
SerpentMage
Hi All. I woke up this morning to an email from my TrueNAS system reporting the following:
New alerts:
* Pool NASPOOL01 state is ONLINE: One or more devices has experienced an unrecoverable error. An attempt was made to correct the error. Applications are unaffected.
I ran zpool status -v and got the following:
  pool: NASPOOL01
 state: ONLINE
status: One or more devices has experienced an unrecoverable error.  An
   see: https://openzfs.github.io/openzfs-docs/msg/ZFS-8000-9P
  scan: scrub repaired 0B in 05:57:26 with 0 errors on Sat Sep 24 05:57:26 2022
        NASPOOL01                                       ONLINE       0     0     0
          raidz1-0                                      ONLINE       0     0     0
            gptid/93b999af-ad5c-11ec-b39e-d05099c29a6f  ONLINE       0     0     0
            gptid/eca3b7a7-ad15-11ec-a6a3-d05099c29a6f  ONLINE       0     0     0
            gptid/3ac69d15-adc4-11ec-b771-d05099c29a6f  ONLINE       0     0     0
            gptid/41ab0ad2-ae07-11ec-85b8-d05099c29a6f  ONLINE       0     0     1
errors: No known data errors
  pool: eDataStore
 state: ONLINE
  scan: scrub repaired 0B in 03:00:19 with 0 errors on Sun Sep 18 03:00:19 2022
        NAME                                                STATE     READ WRITE CKSUM
        eDataStore                                          ONLINE       0     0     0
            gptid/9368e7cf-fe10-11e6-9c83-d05099c00cbc.eli  ONLINE       0     0     0
            gptid/68332ec6-b79c-11e8-a86b-d05099c29a6f.eli  ONLINE       0     0     0
            gptid/95024bc8-fe10-11e6-9c83-d05099c00cbc.eli  ONLINE       0     0     0
            gptid/95c787c3-fe10-11e6-9c83-d05099c00cbc.eli  ONLINE       0     0     0
  pool: freenas-boot
 state: ONLINE
  scan: scrub repaired 0B in 00:03:32 with 0 errors on Fri Sep 23 03:48:32 2022
        freenas-boot  ONLINE       0     0     0
          mirror-0    ONLINE       0     0     0
            da1p2     ONLINE       0     0     0
            da0p2     ONLINE       0     0     0
Which shows a CHSUM error on "gptid/41ab0ad2-ae07-11ec-85b8-d05099c29a6f".
I ran glabel status and found that it was drive ada3. So then I ran smartctl -a /dev/ada3 and got the following:
smartctl 7.2 2021-09-14 r5236 [FreeBSD 13.1-RELEASE-p1 amd64] (local build)
Model Family:     Seagate IronWolf
Device Model:     ST8000VN004-2M2101
Serial Number:    WSD5P4DK
LU WWN Device Id: 5 000c50 0e385cec6
Firmware Version: SC60
User Capacity:    8,001,563,222,016 bytes [8.00 TB]
Rotation Rate:    7200 rpm
Form Factor:      3.5 inches
ATA Version is:   ACS-4 (minor revision not indicated)
SATA Version is:  SATA 3.3, 6.0 Gb/s (current: 6.0 Gb/s)
Local Time is:    Wed Sep 28 06:36:25 2022 MDT
SMART support is: Enabled
General SMART Values:
Offline data collection status:  (0x82) Offline data collection activity
                                        was completed without error.
                                        been run.
data collection:                (  559) seconds.
capabilities:                    (0x7b) SMART execute Offline immediate.
                                        command.
                                        Self-test supported.
                                        power-saving mode.
Short self-test routine
recommended polling time:        (   1) minutes.
Extended self-test routine
recommended polling time:        ( 703) minutes.
Conveyance self-test routine
SCT capabilities:              (0x50bd) SCT Status supported.
                                        SCT Data Table supported.
  1 Raw_Read_Error_Rate     0x000f   081   064   044    Pre-fail  Always       -       124290128
  3 Spin_Up_Time            0x0003   098   098   000    Pre-fail  Always       -       0
  4 Start_Stop_Count        0x0032   100   100   020    Old_age   Always       -       1
  5 Reallocated_Sector_Ct   0x0033   100   100   010    Pre-fail  Always       -       0
  7 Seek_Error_Rate         0x000f   081   060   045    Pre-fail  Always       -       124818267
  9 Power_On_Hours          0x0032   095   095   000    Old_age   Always       -       4431
 10 Spin_Retry_Count        0x0013   100   100   097    Pre-fail  Always       -       0
 12 Power_Cycle_Count       0x0032   100   100   020    Old_age   Always       -       1
 18 Head_Health             0x000b   100   100   050    Pre-fail  Always       -       0
187 Reported_Uncorrect      0x0032   100   100   000    Old_age   Always       -       0
188 Command_Timeout         0x0032   100   100   000    Old_age   Always       -       0
190 Airflow_Temperature_Cel 0x0022   064   057   040    Old_age   Always       -       36 (Min/Max 20/43)
192 Power-Off_Retract_Count 0x0032   100   100   000    Old_age   Always       -       1
193 Load_Cycle_Count        0x0032   100   100   000    Old_age   Always       -       185
194 Temperature_Celsius     0x0022   036   043   000    Old_age   Always       -       36 (0 20 0 0 0)
195 Hardware_ECC_Recovered  0x001a   081   064   000    Old_age   Always       -       124290128
197 Current_Pending_Sector  0x0012   100   100   000    Old_age   Always       -       0
198 Offline_Uncorrectable   0x0010   100   100   000    Old_age   Offline      -       0
199 UDMA_CRC_Error_Count    0x003e   200   200   000    Old_age   Always       -       0
240 Head_Flying_Hours       0x0000   100   253   000    Old_age   Offline      -       4424h+26m+30.571s
241 Total_LBAs_Written      0x0000   100   253   000    Old_age   Offline      -       10617012980
242 Total_LBAs_Read         0x0000   100   253   000    Old_age   Offline      -       86688173271
SMART Error Log Version: 1
No Errors Logged
No self-tests have been logged.  [To run self-tests, use: smartctl -t]
At this point the extent of my ability to read SMART data is basically "yup those are numbers". Would someone be able to check the SMART info and see if I need to look into replacing that drive or if I can just run a zpool clear on it and keep an eye on that drive for a bit?
Thanks for any help!
-John
Redcoat
SMART data looks fine (but note that regular short and long test are not being run...)
CHKSUM errors are often associated with cable/connection issues. I suggest that you carefully reseat the connections for the data cable to the drive and monitor the situation for further reports - if you get another then replace the cable.
SerpentMage
Thanks for the quick assist! Short and long tests should be ran regularly. I'll have to check my smart tasks when I'm off work.
I've had issues with the ports on this MoBo before, so not surprised if it's a port being flaky. Working on building a new server soon.
Thanks again!
