aussiejuggalo
- Apr 26, 2016
I was having problems with access my pool via SMB since upgrading Windows from 2016 - 2019 Enterprise, I was trying to fix that.
In my playing around I stupidly did the Default Permissions in the SMB shares thinking it would reset the permissions to the SMB share and nothing else but it seems to have broken all permissions for the whole NAS, I have no access to the pool from SMB, Plex has no access to the pool at all. So yeah I screwed right up
. I was also an idiot and didn't do any snapshots because I thought this would be a quick fix and the snapshots that were meant to auto run haven't actually been running.
Is there a way I can "undo" this without snapshots or will I have to work out what exactly had the permissions and go from there? I set this up 4 years ago and stuffed if I can remember how I did everything.
I was planning on doing a complete reinstall eventually anyway seeing I've just been upgrading from 9.4 I think it was and some things like snapshots, S.M.A.R.T. tests etc. Haven't actually been auto running but I didn't really want to do that yet... Luckily I'm not that much of an idiot and have everything in the pool backed up externally as well.
