9.3 gui not showing AD users/groups
amwg16
After upgrading to 9.3 Active Directory users/groups don't show up and I can no longer access my SMB shares. When i run wbinfo -u or -g, they show up, but when I go to Storage > Volumes > and check permissions for the dataset, there are no AD users/groups in the drop down. Before the upgrade, I was able to see them in the drop down without any issues.
Anyone else having issues with AD & SMB shares?
depasseg
FreeNAS Replicant
same here
depasseg
FreeNAS Replicant
Thanks! I also saw someone filed a bug report.
depasseg
FreeNAS Replicant
cfa
I too am suffering from this bug. Changing the IDMAP setting in Advanced settings under Active Directory to 'rid' does not help. In fact it makes the problem worse. Running wbinfo -u results in no results
I switched the setting back to 'ad' ... since it stands to reason that an acronym like 'ad' in a section named 'Active Directory' would be appropriate. Now running wbinfo -u gives me the 600+ results I expect from our company domain server.
I've been watching the debug.log during the process. It properly connects but there are some troubling results in there. Here is a snippet:
Dec 26 12:07:38 cfaNAS cachetool.py: [common.freenasldap:177] FreeNAS_LDAP_Directory[ERROR]: An LDAP Exception occured
Dec 26 12:07:38 cfaNAS cachetool.py: [common.freenasldap:184] FreeNAS_LDAP_Directory[ERROR]: desc: 'Size limit exceeded'
Dec 26 12:07:44 cfaNAS cachetool.py: [common.freenasldap:2615] Error on getgrnam: 'getgrnam(): name not found: MYDOMAIN\\Domain Computers'
Dec 26 12:07:44 cfaNAS cachetool.py: [common.freenasldap:2615] Error on getgrnam: 'getgrnam(): name not found: MYDOMAIN\\Domain Users'
Dec 26 12:07:44 cfaNAS cachetool.py: [common.freenasldap:2615] Error on getgrnam: 'getgrnam(): name not found: MYDOMAIN\\Domain Guests'
Dec 26 12:07:44 cfaNAS cachetool.py: [common.freenasldap:2615] Error on getgrnam: 'getgrnam(): name not found: MYDOMAIN\\Group Policy Creator Owners'
Dec 26 12:07:44 cfaNAS cachetool.py: [common.freenasldap:2615] Error on getgrnam: 'getgrnam(): name not found: MYDOMAIN\\Cert Publishers'
Dec 26 12:07:44 cfaNAS cachetool.py: [common.freenasldap:2615] Error on getgrnam: 'getgrnam(): name not found: MYDOMAIN\\RAS and IAS Servers'
Dec 26 12:07:44 cfaNAS cachetool.py: [common.freenasldap:2615] Error on getgrnam: 'getgrnam(): name not found: MYDOMAIN\\info'
Dec 26 12:07:44 cfaNAS cachetool.py: [common.freenasldap:2615] Error on getgrnam: 'getgrnam(): name not found: MYDOMAIN\\payroll'
Dec 26 12:07:44 cfaNAS cachetool.py: [common.freenasldap:2615] Error on getgrnam: 'getgrnam(): name not found: MYDOMAIN\\development'
Dec 26 12:07:44 cfaNAS cachetool.py: [common.freenasldap:2615] Error on getgrnam: 'getgrnam(): name not found: MYDOMAIN\\parentproject'
Dec 26 12:07:44 cfaNAS cachetool.py: [common.freenasldap:2615] Error on getgrnam: 'getgrnam(): name not found: MYDOMAIN\\ticketsales'
Dec 26 12:07:44 cfaNAS cachetool.py: [common.freenasldap:2615] Error on getgrnam: 'getgrnam(): name not found: MYDOMAIN\\donate'
Could these errors be related to the problem with my domain accounts not appearing the security lists ??
