So apparently the x16 slots are by the PCI-spec supposed to be able to supply up to 75W through the slot. Other slots seem to be 25W max. But board vendors might deviate from the spec. So if you go with 9300-16i, then using that aux 6pin power connector will not hurt. If you choose to try without, be sure to read and research that you board can supply the required power as needed.
