Also, i had a question that Broadcom is a manufacturer and are they not aware that the TriMode Adapters will add latency when utilizing the U.2 NVMe drives. So, why they even did that if it does not work well?
I fully believe that it is to protect the lucrative SAS business at all costs. PCIe switches have long been widespread, just not high-performance ones for many lanes. A lot of manufacturers could cash in on that and eat into Broadcom's margins.
SAS meanwhile, has two players: Broadcom and Microchip. The latter probably a step behind in terms of SATA/SAS gear, with LSI/Avago/Broadcom sweeping up two of the big three OEMs (HPE uses both LSI and what is now Microchip, Dell and Lenovo used LSI pretty much exclusively until recently) and much of the whitebox market. That's
a lot of servers.
Let's examine a typical server you may have bought circa 2015, a Dell R630 10-bay. That thing needs one HBA (customized for Dell) and one expander (integrated with the backplane). Retail pricing for a typical RAID controller plus the expander might have been somewhere in the 500-600 buck range, say a third of that is what Broadcom charged Dell for the parts. That's a pretty juicy piece of the action, and there was little that could be done to get away (maybe use fewer disks, and SATA only, but neither of those options were great for a variety of reasons). This R630 had four U.2 tri-mode bays, which was cutting edge at the time and not something you would use willy-nilly.
Fast forward a few years, and in early 2020 you could buy a Dell R6515, same 10-bay form factor. It's still sold with an HBA for SAS, but here's the kicker: Only 8 SATA/SAS disks are supported. They cut the expander. Two bays only do NVMe. Instant savings for everyone and instant sad face for Broadcom execs. And you can even buy it without SAS at all, which is even worse. This is possible because U.2 takes the "we'll tack it onto the side" approach that SAS took with SATA - it's entirely backward-compatible. Just like you could hook up a second SAS port, you can now hook up PCIe and it's independent of the SAS/SATA pins.
Clearly, this scenario was bad for Broadcom and Microchip, so they came up with U.3. Ostensibly, it allows for cheaper backplane PCBs by virtue of needing fewer high-speed differential pairs (by re-using the four existing ones that support the two SAS lanes), more or less halving the count of differential pairs per bay (the clock situation may vary a bit, so the exact count depends on the product). The catch is that the only way it can work is with an expensive tri-mode expander - you
could throw away three of four ports per SATA/SAS device by connecting a controller directly to a bay, but then Broadcom can sell you a monster -32i card just so you can have 8 tri-mode bays. It also means server vendors can't later decide to cut out SAS and still offer SATA from the PCH or SoC, like they can with U.2 - they're stuck with SAS if they want to keep tri-mode U.3 bays.
tl;dr:
- Tri-mode expanders are more expensive than simple PCIe switches;
- U.3, tri-mode HBAs and tri-mode expanders reinforce each other, they make little sense without the other two
- For Broadcom, SAS is a "money printer go BRRRRR" product line, with likely high margins and widespread adoption
