Thronesmelt
- Sep 12, 2014
I was wondering if there would be any problems or comparability issues for freenas with using any of these HBAs? Also of the 2 HBAs which you all consider the higher quality card? I feel like the LSI is the better one of the two but point out any know issues that i am unaware of.
HBAs:
http://www.newegg.com/Product/Product.aspx?Item=N82E16816118142
http://www.newegg.com/Product/Product.aspx?Item=N82E16816103253
Last question. How does this card compare to the M1015? Is it a card that would work at all with FreeNas? Is it a good quality one? It is cheaper in the US here for me then the M1015 so if there is no difference would it be acceptable to use in a build?
http://www.newegg.com/Product/Produ...=Host_Bus_Adapter_Card-_-16-101-792-_-Product
Thank you all for your time.
HBAs:
