Thronesmelt
- Sep 12, 2014
Hello Everyone,
I have changed my CPU and MOBO I am still considering my original one but I will most likely go with the new ones posted below. What are your opinions on a 9 or 12 single vdev RaidZ3 setup with the option to upgrade the case and vdev quantity later. Am I correct that those 2 quantities are the "optimal" configurations for ZFS RaidZ3? I am thinking most likely 9 for less chance of total data loss and Zpool due to drive failures during resilvering. I am just keeping my options open and would like recommendations.
With all that said here are my Potential Parts:
Case:
http://www.newegg.com/Product/Product.aspx?Item=N82E168...
NEW
Motherboard:
http://www.newegg.com/Product/Product.aspx?Item=N82E16813182822
NEW
CPU:
http://www.newegg.com/Product/Product.aspx?Item=N82E16819117315
RAM:
2 x http://www.newegg.com/Product/Product.aspx?Item=N82E16820148770
Power Supply Unit: (Currently Own)
5.25" Expander for more 3.5" Drive Space:
http://www.newegg.com/Product/Produ..._25_to_3_5_bay_adapter-_-17-994-152-_-Product
FreeNas OS USB Stick:
http://www.newegg.com/Product/Product.aspx?Item=N82E16820211668
HBA:
IBM M1015
Fans to cool the case:
7 of these http://www.newegg.com/Product/Product.aspx?Item=N82E168...
2 Of these top mount http://www.newegg.com/Product/Product.aspx?Item=N82E168...
HDDs:
5 or 7 of these http://www.newegg.com/Product/Product.aspx?Item=9SIA5EM...
4 or 5 of these http://www.newegg.com/Product/Product.aspx?Item=N82E16822236350
The hard drive quantities above are not the Vdev breakdown but just the physical quantities of each. I will not be purchasing all the drives from just a single retailer. I will be using many different online sellers but it is just easier to link to Newegg so you all can have a clear understanding of my parts list.
(Secondary Considerations:
Motherboard:
CPU:
http://www.newegg.com/Product/Product.aspx?Item=N82E168...)
Thank you all for your help and advice. I greatly appreciate any who take the time to read and reply.
Case:
NEW
Motherboard:
NEW
CPU:
RAM:
HBA:
IBM M1015
HDDs:
Motherboard:
CPU:
