As a TrueNAS user for a few months, I have been very satisfied with its performance. The current configuration of my server is as follows:
- TrueNAS Core
- ASUS X99 DELUXE II
- Intel 6950X CPU 10c/20t
- 128GB DDR4 RAM
- Intel X550 10G NIC
- 8x 16TB Ironwolf Pro Drives (Data VDEV 3x MIRROR-6Wide+1 Hotspare +1 coldspare)
- 2x 250GB Ironwolf 125 SATA SSD (mirrored metadata vdev)
- 1x Intel 750 U.2 400GB NVME (L2ARC)
- 1x Intel 600P 512GB NVME (boot drive)
- Fractal Designs Meshify 2 Case
I utilize this server for my photography work and currently have a 32TB iSCSI share mapped to my workstation that contains all my RAW files, video files, documents, and photos. However, as the hardware is more geared towards consumer/gaming use, I am planning to upgrade to server-grade components for added peace of mind.
My initial build list is as follows, and I already have a 3-2-1 backup of all my data:
- AsRock Rack SPC621D8-2T ATX Server Motherboard LGA 4189
- Intel Xeon Silver 4310 Ice Lake 2.1 GHz CPU 12C/24T
- NEMIX RAM 128GB 8x16GB DDR4-2666 PC4-21300 2Rx8 ECC Registered Memory
- Noctua NH-U12S DX-4189 Heatsink/FAN
My plan is to migrate the pool to the new hardware with a fresh install of TrueNAS CORE while using the same chassis. I also plan on utilizing the SATA ports on the new motherboard for the hard drives. However, I will remove the L2ARC drive from the pool prior to export as the new motherboard does not have a U.2 port.
While this setup may be considered overkill for my use case, I welcome any suggestions or feedback.
- TrueNAS Core
- 128GB DDR4 RAM
