I am exploring options to build TrueNAS Server for home use.
Currently I have 3 NAS units (Drobo5N, Synology, D-Link with over 50TB of data mostly video & audio)
I hav been assembling my own PCS for past 2 decades (Windows PC only)
Zero experience with Linux/ TrueNAS
Hardware Shorlisted:
Casing: Fractal Node 804 (MicroATX) (Already purchsed)
Motherboard: SuperMicro X12STH-LN4F 'OR' X12STH-F
CPU: Intel Xeon E-2334
RAM: 128MB (32x4) Kingston 32GB 288-Pin DDR4 SDRAM ECC Unbuffered DDR4 3200 (PC4 25600)
HDD: WD Ultrastar HC570 22TB (planning to procure in phases - need your advise to start with minimum count, will eventually get 8 HDDs)
PSU: 850W modular
Internal HD Mini SAS to 4XSATA Cable - 01
M.2 SSD - advice required
Budget - $4-5K
Appreciate your feedback/ advice/guidance/ suggestions.
Thank You.
PSU: 850W modular
Budget - $4-5K
Thank You.
