pioto
- Apr 11, 2017
I'm looking to replace my circa-2015 TrueNAS box with some fresher technology. My current use cases:
I'm also open to revisiting my zpool strategy, which over my last few FreeNAS iterations boils down to "2x xTB disks as a mirror, grow by swapping with yTB one at a time, or adding another 2 xTB later". I see there's a newer draid option, and for my use case raidz may also make more sense (but my historical impression was that it was harder to grow over time, and required at more drives up-front). My initial thoughts would be to get a pair of 8+TB WD Reds, and maybe add another pair if my usage grows faster than planned.
Final "nice to have" would be external hot-swappable drive bays and a quiet, relatively low-profile & power efficient chassis. This system will be behind me in my home office every day while I'm on conference calls and the like, so it can't sound like a jet plane taking off like the Proliant I used to use!
Initial Shopping Cart
Here's what I've put together so far from Newegg:
Edit: reading around I came across someone else asking my pool question right before my post (sorry). So that makes me consider the alternative of 4x 4TB drives in a raidz2, for the same raw storage capacity, but the capability to withstand 2 drive failures... on Newegg looks like that only costs $10 more to do, but then I'm committed to buying 4x 6/8/... TB drives all at once if I need more capacity...
- Backup storage (2.46TB currently
hoardedaccumulated since ~2009, figure that'll grow to at least 4TB over the life of this system, some blend of rsync pull tasks, plus external systems pushing via SMB or duplicity+ssh) - Plugins / Apps
- Plex (total media library ~750GB, expect that would grow to 1.5-2TB over the life of this system) - typically only 1-2 active streams at most, most video is only 480p, some 1080p, but maybe some 4k content over the overall life of this system). So supporting hardware transcoding is something I'm considering (my current build is AMD w/ no discrete GPU so it's not supported), but probably not a deal breaker.
- Syncthing (main share a single KeePass file, but also to backup photos from my phone, so practically "nothingburger" territory)
- A FreeBSD VM (pretty much just to keep IRSSI idling in)
- Case + PSU: Supermicro SuperChassis CSE-721TQ-350B2 Mini ITX Mini Tower, 4 x 3.5" Hotswap Bays
- Motherboard + CPU: SUPERMICRO MBD-M11SDV-4CT-LN4F-O Mini ITX Server Motherboard
- RAM: Crucial 32GB (2 x 16GB) 288-Pin DDR4 SDRAM ECC Registered DDR4 2133 (PC4 17000) Server Memory Model CT2K16G4RFD4213
- Boot Disk: Transcend MTS800 M.2 2280 32GB SATA III MLC Internal Solid State Drive (SSD) TS32GMTS800
- Storage Disks (2x): WD Red Plus 8TB CMR NAS Hard Drive HDD - 5640 RPM, SATA 6 Gb/s, 128MB Cache, 3.5" - WD80EFZZ - OEM
