CheckYourSix
- Jun 14, 2015
Has there been any updates? I'm really interested in this build. Also, if you won't mind, what do you use the ESXi VMs for?
Which Switch do you have?It has been moving and sharing some movie files without issues and the 10GbE network awesome. The Intel X540T1 cards and Netgear switch work amazingly fast at moving data and I'd recommend them to those who have the cash, which is the only downside and is expensive no doubt. I had one evening where I had 4 transcoding streams running while moving about 8TB of data and the system didn't blink. The server itself, housed in the basement remains cool and blazing fast. CPU temps have yet to hit 45c and all 19 hard drives remain between 27-29c idle with a max temp of 34c when streaming. Power consumption averages around 233W with the highest peek at 288.
Good recommendation, half the RAM and lower CPU are indeed enough for most home users! ;)Can't really go wrong with the freenas hardware setup I used, the install is straight forward and just setup the system for your requirements. For savings, skip the 10GbE networking, drop down a step in the CPU department, half the ram to start, setup 6 or 8 drives to begin with and it's a huge price drop initially that would give an awesome setup for any home user with tons of expansion far into the future.
Go big or go home :p look at https://forums.freenas.org/index.ph...846-chassis-72-disks.30431/page-9#post-209698You could also start with the suggested reduced system in a smaller chassis and without the expanded/s and move up later...
You dont have rack rails for any of those servers? I just picked up a rack specially so i dont have to rack and unrack them to get to the bottom or middle.I did as you suggested (except reseating the Sata DOM since that would have meant pulling everything back out of the rack), and it does still not show up as a boot option. However, I was able to choose it from the Boot Override list as I exited the BIOS. Boot speed is about the same as booting from USB, but at least SATA DOM should be a bit more reliable than USB from what I gather.
Of course I'm now getting the boot volume in a degraded state alert since I pulled the USB and I'm running off the SATA DOM mirror. Next time I take the whole system down and pull out the chassis, maybe I'll try moving the DOM to the SATA5 slot to see if that helps.
I have one set of rack rails, but they don't fit the middle server as the hole spacing appears to have changed somewhere along the way with the 846 chassis. I have it on my todo list to look at when the change occurred and pick up another couple of sets :)
I'm also looking at a bracket for the LCD monitor to tighten that up a little better as well.
Sigh.. I still haven't purchased a rack and everything is sitting neatly out on a table, my workbench and table saw for now. I'll need to find something soon. Thankfully, all my rack chassis included rails except for the small one I bought for the pfSense server which I don't think accepts rails at all. Its so small and light its not a big deal anyways.
I'm intrigued... how is the pfSense box (with its quad-NIC) connected to all this?I have the Netgear ProSafe XS708E 10GbE switch and use 4 of the Intel X540-T1 network cards in my desktop PC, FreeNAS server, ESXi server and an email/web server for now.
I was referring to the 10GbE ports in your switchI don't see it as "port waste" but future "port expansion". ;) I will be using Port3 later this or early next year so it really just leaves me with a single unused port.
