DataKeeper
- Feb 19, 2015
If you have or can pickup an older or inexpensive PC you can play with it instead of expensive server hardware to start. It really is easy. A table and screwdriver is all that's needed. Taking it apart and then rebuilding is pretty much the same as a larger system like mine. Just the server hardware is a bit more particular with what works best with it.
The software part is easy especially on PC hardware to start with. Also, take an old PC and install FN or if the hardware doesn't work with it give OpenMediaVault a try. It's the Debian Linux based alternative to FreeNAS which is what I had originally and then again later thought I'd use. It's also my preferred OS!
Basically this stuff you can easily play with and learn as you go. If you have any questions feel free to ask me or others on the forum.
