[root@FileServ] ~# smartctl -x /dev/da12
smartctl 6.3 2014-07-26 r3976 [FreeBSD 9.3-RELEASE-p13 amd64] (local build)
Copyright (C) 2002-14, Bruce Allen, Christian Franke,
www.smartmontools.org
Model Family: Western Digital Red
Device Model: WDC WD40Exxxxxxxxxx
Serial Number: WD-WCC4Exxxxxxx
LU WWN Device Id: 5 0014ee 20b2f8c09
Firmware Version: 82.00A82
User Capacity: 4,000,787,030,016 bytes [4.00 TB]
Rotation Rate: 5400 rpm
ATA Version is: ACS-2 (minor revision not indicated)
SATA Version is: SATA 3.0, 6.0 Gb/s (current: 6.0 Gb/s)
Local Time is: Mon May 4 18:45:21 2015 EDT
SMART support is: Enabled
AAM feature is: Unavailable
APM feature is: Unavailable
Rd look-ahead is: Enabled
Write cache is: Enabled
ATA Security is: Disabled, NOT FROZEN [SEC1]
Wt Cache Reorder: Enabled
General SMART Values:
was never started.
been run.
data collection: (52560) seconds.
command.
Self-test supported.
power-saving mode.
Short self-test routine
Extended self-test routine
recommended polling time: ( 526) minutes.
Conveyance self-test routine
recommended polling time: ( 5) minutes.
SCT capabilities: (0x703d) SCT Status supported.
SCT Data Table supported.
ID# ATTRIBUTE_NAME FLAGS VALUE WORST THRESH FAIL RAW_VALUE
1 Raw_Read_Error_Rate POSR-K 193 192 051 - 806
3 Spin_Up_Time POS--K 100 253 021 - 0
4 Start_Stop_Count -O--CK 100 100 000 - 5
5 Reallocated_Sector_Ct PO--CK 200 200 140 - 0
7 Seek_Error_Rate -OSR-K 100 253 000 - 0
9 Power_On_Hours -O--CK 100 100 000 - 86
10 Spin_Retry_Count -O--CK 100 253 000 - 0
11 Calibration_Retry_Count -O--CK 100 253 000 - 0
12 Power_Cycle_Count -O--CK 100 100 000 - 5
192 Power-Off_Retract_Count -O--CK 200 200 000 - 3
193 Load_Cycle_Count -O--CK 200 200 000 - 72
194 Temperature_Celsius -O---K 126 121 000 - 26
196 Reallocated_Event_Count -O--CK 200 200 000 - 0
197 Current_Pending_Sector -O--CK 200 200 000 - 133
198 Offline_Uncorrectable ----CK 100 253 000 - 0
199 UDMA_CRC_Error_Count -O--CK 200 200 000 - 0
200 Multi_Zone_Error_Rate ---R-- 200 200 000 - 0
||||||_ K auto-keep
|||||__ C event count
||||___ R error rate
|||____ S speed/performance
||_____ O updated online
|______ P prefailure warning
General Purpose Log Directory Version 1
SMART Log Directory Version 1 [multi-sector log support]
Address Access R/W Size Description
0x00 GPL,SL R/O 1 Log Directory
0x01 SL R/O 1 Summary SMART error log
0x02 SL R/O 5 Comprehensive SMART error log
0x03 GPL R/O 6 Ext. Comprehensive SMART error log
0x06 SL R/O 1 SMART self-test log
0x07 GPL R/O 1 Extended self-test log
0x09 SL R/W 1 Selective self-test log
0x10 GPL R/O 1 NCQ Command Error log
0x11 GPL R/O 1 SATA Phy Event Counters
0x21 GPL R/O 1 Write stream error log
0x22 GPL R/O 1 Read stream error log
0x80-0x9f GPL,SL R/W 16 Host vendor specific log
0xa0-0xa7 GPL,SL VS 16 Device vendor specific log
0xa8-0xb7 GPL,SL VS 1 Device vendor specific log
0xbd GPL,SL VS 1 Device vendor specific log
0xc0 GPL,SL VS 1 Device vendor specific log
0xc1 GPL VS 93 Device vendor specific log
0xe0 GPL,SL R/W 1 SCT Command/Status
0xe1 GPL,SL R/W 1 SCT Data Transfer
SMART Extended Comprehensive Error Log Version: 1 (6 sectors)
Device Error Count: 461 (device log contains only the most recent 24 errors)
CR = Command Register
FEATR = Features Register
COUNT = Count (was: Sector Count) Register
LBA_48 = Upper bytes of LBA High/Mid/Low Registers ] ATA-8
LH = LBA High (was: Cylinder High) Register ] LBA
LM = LBA Mid (was: Cylinder Low) Register ] Register
LL = LBA Low (was: Sector Number) Register ]
DV = Device (was: Device/Head) Register
DC = Device Control Register
ER = Error register
ST = Status register
Error 461 [4] occurred at disk power-on lifetime: 83 hours (3 days + 11 hours)
ER -- ST COUNT LBA_48 LH LM LL DV DC
40 -- 51 00 00 00 00 67 9f 06 60 40 00 Error: UNC at LBA = 0x679f0660 = 1738475104
CR FEATR COUNT LBA_48 LH LM LL DV DC Powered_Up_Time Command/Feature_Name
60 00 02 00 00 00 00 67 9f 06 60 40 00 2d+13:38:21.069 READ FPDMA QUEUED
60 00 02 00 00 00 00 67 9f 06 5e 40 00 2d+13:38:21.069 READ FPDMA QUEUED
60 00 02 00 00 00 00 67 9f 06 5c 40 00 2d+13:38:21.069 READ FPDMA QUEUED
60 00 02 00 00 00 00 67 9f 06 5a 40 00 2d+13:38:21.069 READ FPDMA QUEUED
60 00 02 00 00 00 00 67 9f 06 58 40 00 2d+13:38:21.069 READ FPDMA QUEUED
Error 460 [3] occurred at disk power-on lifetime: 82 hours (3 days + 10 hours)
40 -- 51 00 00 00 00 67 6b 77 18 40 00 Error: UNC at LBA = 0x676b7718 = 1735096088
60 00 02 00 00 00 00 67 6b 77 18 40 00 2d+13:35:59.568 READ FPDMA QUEUED
60 00 02 00 00 00 00 67 6b 77 16 40 00 2d+13:35:59.568 READ FPDMA QUEUED
60 00 02 00 00 00 00 67 6b 77 14 40 00 2d+13:35:59.568 READ FPDMA QUEUED
60 00 02 00 00 00 00 67 6b 77 12 40 00 2d+13:35:59.568 READ FPDMA QUEUED
60 00 02 00 00 00 00 67 6b 77 10 40 00 2d+13:35:59.568 READ FPDMA QUEUED
Error 459 [2] occurred at disk power-on lifetime: 82 hours (3 days + 10 hours)
40 -- 51 00 00 00 00 67 6a 50 60 40 00 Error: UNC at LBA = 0x676a5060 = 1735020640
60 00 02 00 00 00 00 67 6a 50 60 40 00 2d+13:35:33.740 READ FPDMA QUEUED
60 00 02 00 00 00 00 67 6a 50 5e 40 00 2d+13:35:33.739 READ FPDMA QUEUED
60 00 02 00 00 00 00 67 6a 50 5c 40 00 2d+13:35:33.739 READ FPDMA QUEUED
60 00 02 00 00 00 00 67 6a 50 5a 40 00 2d+13:35:33.739 READ FPDMA QUEUED
60 00 02 00 00 00 00 67 6a 50 58 40 00 2d+13:35:33.739 READ FPDMA QUEUED
Error 458 [1] occurred at disk power-on lifetime: 82 hours (3 days + 10 hours)
40 -- 51 00 00 00 00 67 67 f5 d4 40 00 Error: UNC at LBA = 0x6767f5d4 = 1734866388
60 00 02 00 00 00 00 67 67 f5 d4 40 00 2d+13:34:46.941 READ FPDMA QUEUED
2f 00 00 00 01 00 00 00 00 00 10 40 00 2d+13:34:46.937 READ LOG EXT
60 00 02 00 00 00 00 67 67 f5 d2 40 00 2d+13:34:43.533 READ FPDMA QUEUED
2f 00 00 00 01 00 00 00 00 00 10 40 00 2d+13:34:43.529 READ LOG EXT
60 00 02 00 00 00 00 67 67 f5 d0 40 00 2d+13:34:40.293 READ FPDMA QUEUED
Error 457 [0] occurred at disk power-on lifetime: 82 hours (3 days + 10 hours)
40 -- 51 00 00 00 00 67 67 f5 d2 40 00 Error: UNC at LBA = 0x6767f5d2 = 1734866386
60 00 02 00 00 00 00 67 67 f5 ce 40 00 2d+13:34:40.293 READ FPDMA QUEUED
60 00 02 00 00 00 00 67 67 f5 cc 40 00 2d+13:34:40.293 READ FPDMA QUEUED
Error 456 [23] occurred at disk power-on lifetime: 82 hours (3 days + 10 hours)
40 -- 51 00 00 00 00 67 67 f5 d0 40 00 Error: UNC at LBA = 0x6767f5d0 = 1734866384
60 00 02 00 00 00 00 67 67 f5 ca 40 00 2d+13:34:40.293 READ FPDMA QUEUED
60 00 02 00 00 00 00 67 67 f5 c8 40 00 2d+13:34:40.293 READ FPDMA QUEUED
Error 455 [22] occurred at disk power-on lifetime: 82 hours (3 days + 10 hours)
40 -- 51 00 00 00 00 67 67 5b 2a 40 00 Error: UNC at LBA = 0x67675b2a = 1734826794
60 00 02 00 00 00 00 67 67 5b 2a 40 00 2d+13:34:25.807 READ FPDMA QUEUED
2f 00 00 00 01 00 00 00 00 00 10 40 00 2d+13:34:25.803 READ LOG EXT
60 00 02 00 00 00 00 67 67 5b 28 40 00 2d+13:34:22.499 READ FPDMA QUEUED
60 00 02 00 00 00 00 67 67 5b 26 40 00 2d+13:34:22.499 READ FPDMA QUEUED
60 00 02 00 00 00 00 67 67 5b 24 40 00 2d+13:34:22.499 READ FPDMA QUEUED
Error 454 [21] occurred at disk power-on lifetime: 82 hours (3 days + 10 hours)
40 -- 51 00 00 00 00 67 67 5b 28 40 00 Error: UNC at LBA = 0x67675b28 = 1734826792
60 00 02 00 00 00 00 67 67 5b 22 40 00 2d+13:34:22.499 READ FPDMA QUEUED
60 00 02 00 00 00 00 67 67 5b 20 40 00 2d+13:34:22.499 READ FPDMA QUEUED
SMART Extended Self-test Log Version: 1 (1 sectors)
# 1 Extended offline Completed without error 00% 36 -
# 2 Extended offline Interrupted (host reset) 90% 11 -
# 3 Conveyance offline Completed without error 00% 11 -
# 4 Short offline Completed without error 00% 10 -
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
SCT Status Version: 3
SCT Version (vendor specific): 258 (0x0102)
SCT Support Level: 1
Device State: Active (0)
Current Temperature: 26 Celsius
Power Cycle Min/Max Temperature: 20/29 Celsius
Lifetime Min/Max Temperature: 18/29 Celsius
Under/Over Temperature Limit Count: 0/0
SCT Temperature History Version: 2
Temperature Sampling Period: 1 minute
Temperature Logging Interval: 1 minute
Min/Max recommended Temperature: 0/60 Celsius
Min/Max Temperature Limit: -41/85 Celsius
Temperature History Size (Index): 478 (398)
Index Estimated Time Temperature Celsius
399 2015-05-04 10:48 29 **********
... ..(245 skipped). .. **********
167 2015-05-04 14:54 29 **********
168 2015-05-04 14:55 28 *********
... ..(155 skipped). .. *********
324 2015-05-04 17:31 28 *********
325 2015-05-04 17:32 27 ********
... ..( 8 skipped). .. ********
334 2015-05-04 17:41 27 ********
335 2015-05-04 17:42 26 *******
... ..( 62 skipped). .. *******
398 2015-05-04 18:45 26 *******
SCT Error Recovery Control:
Read: 70 (7.0 seconds)
Write: 70 (7.0 seconds)
Device Statistics (GP Log 0x04) not supported
SATA Phy Event Counters (GP Log 0x11)
ID Size Value Description
0x0001 2 0 Command failed due to ICRC error
0x0002 2 0 R_ERR response for data FIS
0x0003 2 0 R_ERR response for device-to-host data FIS
0x0004 2 0 R_ERR response for host-to-device data FIS
0x0005 2 0 R_ERR response for non-data FIS
0x0006 2 0 R_ERR response for device-to-host non-data FIS
0x0007 2 0 R_ERR response for host-to-device non-data FIS
0x0008 2 0 Device-to-host non-data FIS retries
0x0009 2 2 Transition from drive PhyRdy to drive PhyNRdy
0x000a 2 3 Device-to-host register FISes sent due to a COMRESET
0x000b 2 0 CRC errors within host-to-device FIS
0x000f 2 0 R_ERR response for host-to-device data FIS, CRC
0x0012 2 0 R_ERR response for host-to-device non-data FIS, CRC
0x8000 4 235534 Vendor specific
