Hardware Question for New Build
HELLiON
Before I pull the trigger on this, I was wondering about this CPU/mobo combination.
E5-2695 v3 CPU with a X10SRM-TF motherboard. Leaning towards a Fractal Design 804 so mATX is preferred. Really the two mATX motherboard options are X10SRM-TF and X10SRM-F for that CPU.
Found the CPU for $230 which seems fairly cheap considering the passmark score it gets.
pro lamer
Hi, have you bought it. Is it doing well? Did you use the iPASS mobo SATA connector? Is it plain 8087 connector or a supermicro proprietary one?
Sent from my phone
