onlineforums
- Oct 1, 2017
I have an iX systems TrueNAS Mini XL+ that is 5+ years old that has 8 HDDs. Recently the boot drive, the original internal SATADOM showed degraded so I turned the machine off, ordered a 2.5 SSD and then waited about a week to install it and reinstall using the SSD. In that period of time I did blow out the inside using only my breath (not canned air).
I mounted the SSD, plugged in the SATA and power cable into it and then plugged in the PSU power cable. Immediately upon plugging in the main power supply power cable the unit turned on and then within 3 seconds turned off. There are two lights on the motherboard that stay illuminated. After about 60 seconds the led that is illuminated toward the rear near the battery starts blinking on and off. I tried pushing the power button on the front of the case which did nothing; I checked the cable from the power button to the motherboard and it is still in-tact. I tried using paperclip in-lieu of the power button cable and it did nothing.
Really bizarre. I suspect it has to do with blowing into the side (not super close) to get the dust out or maybe it just didn't like being turned off for over a week when it has been running 24/7 for the past 5+ years.
Any thoughts or suggestions to help with diagnosing what is going on?
I have already removed/tried the following followed by plugging the unit into the power outlet after each to no avail:
- Removed the SSD drive (and bay/container)
- Removed the 8 hot-swappable HDDs from the front
- Removed all RAM sticks.
