alieg
- Jul 12, 2013
So, I've had my FreeNAS for a couple of years and things have been fine...
A few days ago I noticed the GUI page wasn't loading and its IP wasn't listed as online.
I rebooted, and left it to do it's thing, until a couple of days later when I checked it...
I noticed it was still mid-way through the boot sequence; unfortunately I can't remember exactly what it said, but I got the impression that my USB was at fault.
I created a new 9.3.1 bootable USB on my macbook and got to the initial stage, where you select new installation.
After pressing enter, the PC powered off. I tried to boot it up, but nothing happened.
There was a light near the power button, but the fans were off.
I removed and re-inserted the power cable - still no power.
I removed the power cable, and left it for 24 hours. I tried my original USB on a laptop - it booted, but didn't complete, as I assume it couldn't find the HDD's.
I tried this original USB on my FreeNAS PC; it booted for probably around 30 seconds; turned itself off, and wouldn't power on as before.
After a bit of reading, I replaced the CMOS battery; it booted and stopped mid-way, but the power didn't go off.
This happened twice at different places in the boot sequence - first after mentioning a USB mouse (which I then removed), and then after geom_raid5 module loaded.
I tried booting from my new installation USB; it got a little further than the first attempt, until it couldn't find any drives to install on
I had taken out my HDD's before this, so I shutdown; replaced their cables; pressed the power button... no power again. The lights are on, but nobody's home.
I Replaced the CMOS battery for a 2nd time, but still nothing happened when I pressed the power button.
I've now taken the power cable out and will have to wait until tomorrow to try again.
Sorry it's very vague of specific details / errors. I've been looking at old server PC's on eBay, as I assume it's something to do with my motherboard / PSU.
I had a bit of hope that it was just the CMOS battery. It's been a good machine, and has been quietly doing its thing, so I couldn't even say for certain what version I was running!
Anyway, I don't expect too much from the info I've provided; I wondered if someone might be able to re-assure my thoughts, that it's a dying hardware issue, rather than something that would re-occur if I bought a new PC.
