Harddrive wont start smartd/serial is too long
adam mackey
Not sure where the best place to post this is as this is my first post. I cannot get the smart service to start. I have tried enabling it from the gui and shell with no joy. I fould that smart does not seem to be enabled for drive da0. I tried starting it vi shell with this command smartctl --smart=on /dev/da0 the error I recieve is
=== START OF ENABLE/DISABLE COMMANDS SECTION ===
unable to fetch IEC (SMART) mode page [scsi response fails sanity test]
A mandatory SMART command failed: exiting. To continue, add one or more '-T perm
issive' options.
there are 7 drives of the same type and manufacturer HGST all drives da0-da6 fail to start smart. when I try to change any of those disks via gui I get an error that says the serial is to long 32 characters and should not exceed 30. I am using a lsi raid card with drives set to raid 0 because it doesnt support JBOD. It seems like that could be interferring with smart but idk about the serial thing. Any help is appreciated and I will get specifics as to raid card model and drive type when I am able to pull the freenas box from operation.
This is a problem. It may or may not be what's causing the problem you're currently seeing, but it's definitely a problem.
What's the output of smartctl -a /dev/da0?
adam mackey
Sorry for the delay just got home from work here is the output of -a
Vendor: LSI
Product: MR9271-8i
Revision: 3.22
User Capacity: 1,999,844,147,200 bytes [1.99 TB]
Logical block size: 512 bytes
>> Terminate command early due to bad response to IEC mode page
issive' options.
I tried this next not sure what -T verypermissive means
[root@Datastore01 ~]# smartctl -T verypermissive -a /dev/da0
smartctl 6.5 2016-05-07 r4318 [FreeBSD 11.0-STABLE amd64] (local build)
Copyright (C) 2002-16, Bruce Allen, Christian Franke, www.smartmontools.org
Vendor: LSI
Product: MR9271-8i
Revision: 3.22
Current Drive Temperature: 0 C
Drive Trip Temperature: 0 C
Read defect list: asked for grown list but didn't get it
Error Counter logging not supported
Device does not support Self Test logging
Stux
DrKK
FreeNAS Generalissimo
VERY. STRONGLY. RECOMMEND. YOU. NOT. RUN. FREENAS. WITH. A. HARDWARE. RAID. CARD.
adam mackey
does anyone have suggestions on an hard drive HBA I think I have an adaptec raid controller that supports JBOD. Is a regular HBA preferred over RAID JBOD as well? I want somthing that will just let freenas do its thing and not interfere with the ZFS RAID right?
