cplmayo
 - Nov 20, 2014
This is my first post; I've tried to search around the forums and google before coming here to post this so please be kind if I missed a thread.
Let me start with my setup.
MB: Supermicro X7DCL-i
CPU: Dual Xeon E5410
RAM: 24GB DDR2 ECC
HBA: IBM 25R8071/LSI SAS 3444E
Enclosure: Xtore 2U 12Bay - built in SAS Expander
HDDS: 2xWD 2TB RE4
4xWD 2TB Greens
The HBA I'm using is weak and the Green drives need to go but this is what I have until my budget facilitates me upgrading to better HDDs and a better HBA.
My problem:
In the GUI I don't get any serial numbers for any of the Hard Drives. Also from what I can tell the pre-built script for smartd will not return any information.
Ran down the rabbit hole on this and found this.
So obviously the HDDs support SMART and the information can be read directly from the drives. I think it is something in the default settings in FreeNAS that is not passing the information through the HBA card to the drives.
Is there a tunable or setting that I need to change to properly pass the information so I can monitor my HDDs and have the serials in the GUI. Putting any data on the Green drives worries me without SMART reporting because they are prone to problems.
RAM: 24GB DDR2 ECC
HDDS: 2xWD 2TB RE4
4xWD 2TB Greens
My problem:
smartctl /dev/da0 -a smartctl 6.2 2013-07-26 r3841 [FreeBSD 9.2-RELEASE-p15 amd64] (local build) Copyright (C) 2002-13, Bruce Allen, Christian Franke, www.smartmontools.org Probable ATA device behind a SAT layer Try an additional '-d ata' or '-d sat' argument.
smartctl /dev/da0 -a -d scsi smartctl 6.2 2013-07-26 r3841 [FreeBSD 9.2-RELEASE-p15 amd64] (local build) Copyright (C) 2002-13, Bruce Allen, Christian Franke, www.smartmontools.org User Capacity: 2,000,398,934,016 bytes [2.00 TB] Logical block size: 512 bytes Logical Unit id: 0x50014ee0ada02dd1 Serial number: WD-WMAY03848157 Device type: disk Local Time is: Sat Nov 22 10:51:32 2014 EST SMART support is: Available - device has SMART capability. SMART support is: Enabled Temperature Warning: Disabled or Not Supported === START OF READ SMART DATA SECTION === SMART Health Status: OK Error Counter logging not supported Device does not support Self Test loggin
