itsryan
- Jan 11, 2017
This should be a simple question that i'm assuming the answer, I would just like to make sure before I pull the trigger.
I currently have 6 2TB WD RED drives in my NAS over the next few months I will be buying replacement drives to expand the storage. I'm looking to get 6 10TB drives.
1. Since I will most likely be buying the drives one at a time, should I install the drive right when I get them and rebuild the pool and wait a month or 2 until I have the next drive and install it or should I wait until I have all the replacement drives then start swapping the drives out.
2. All my drives currently spin at 5400 RPM, should the replacement drives also spin at 5400 RPM or should I get 7200 RPM drives. Keeping in mind my NAS is a home server that is used only for PLEX and family videos/pictures. 2-3 Users.
3. Will FreeNAS care if some HHDs spin at 5400 and some might spin at 7200?
4. I know most of the community uses/prefers WD over Seagate. But the Seagate drives are less expensive (Money is a factor in my build). Is their a known difference between WD red and Seagate Ironwolf other then price?
5. When I setup the pool a created it as RAIDZ1, what is the easiest way to switch it to RAIDZ2 once I have all the new drives.
If someone could answer this 5 questions for me I would be grateful for your help.
