I'm having an issue with my new FreeNAS system.   I've just recently built the system and am going through the burn-in testing.
I have a ASRock C2550D4i based system with 32GB ECC memory and 6 @ 4TB hard drives.
3 of the hard drives are Western Digital RED's and 3 are Seagate NAS drives.
(Here's a link to my build thread: https://forums.freenas.org/index.php?threads/new-to-freenas-please-review-my-build-plan.40269/)
I've run the smartctl short, conveyance and long tests and am now running the badblocks tests.
Everything is looking good on the WD hard drives, however, I've noticed that the Seagate drives have high Raw_Read_Error_Rate numbers.
Here's an example. The raw value is 15,196,360 for the Raw_Read_Error_Rate
1 Raw_Read_Error_Rate 0x000f 108 100 006 Pre-fail Always - 15196360
Also, the Seek_Error_Rate is high:
Seek_Error_Rate 0x000f 100 253 030 Pre-fail Always - 22201
I've checked the smart values for all 3 Seagate drives and they are all equally high (not the same value, but >10million for the Raw_Read_Error_Rate.
Does this mean the drives are bad?
The hard drive burn in guide indicates some of the more important fields are Reallocated_Sector_Ct, Current_Pending_Sector, and Offline_Uncorrectable, however, I'm not seeing errors there.
Should I go ahead and return the Seagates and get different drives (would probably buy WD RED's again).
Thanks
Thanks
