SOLVED GUI Certificate Error on Chrome for OSX
DLMJOSLIN
I have had no issues getting a secure connection to the web GUI until about two months ago. Now Chrome and firefox for OSX tells me the connection is not secure and gives the following error: NET::ERR_CERT_COMMON_NAME_INVALID. I am able to get a secure connection with firefox for linux, but not with chrome for linux. I have the latest updates for all the browsers & FreeNAS. I also have no extensions enabled and no firewall enabled. Any additional information needed I will try to provide.
Update 02JUN2017: Now Firefox for OSX gets a secure connection.
Found the Bug Report.
joeschmuck
Old Man
Glad you went searching and found the bug report.
DLMJOSLIN
I tried finding it before I asked on the forum, I guess I didn't look hard enough. Hopefully anyone else having this issue will have a much easier time finding the cause.
zoomzoom
This is easy enough to solve by using an openssl.cnf with OpenSSL to generate a CA and use it to sign certs. I have a pre-built openssl.cnf in my signature which has all commands, and explanations, starting about halfway down (4 commands to create CA, 3 to create, sign, and export to P12 for client certs)
That's a corollary of Murphy's Law - your answers will inevitably be obvious just after you post your question.
DLMJOSLIN
Just like when you try to show someone an issue, but when you get there the issue magically resolved and your unable to reproduce whatever the problem was.
DLMJOSLIN
Thank you I'll try that out when I get home and update you.
Yup, good ol' Murphy strikes everywhere.
