Grub issue after upgrading from Core to Scale
markds
Took the plunge and attempted to upgrade one of my Truenas Core 12-U8 boxes to Truenas Scale 22.02.0.1 via the manual update method. Everything worked well, but after installing the system boots to a grub error.
GRUB Loading..
Welcome to GRUB!
error: unknown filesystem.
Entering rescue mode...
grub rescue>
From the rescue shell I can "ls" and see my boot device as well my 4 drives in my pool.
However I can not do an ls of any of the partitions. ie "ls (hd0,gpt1)"
I am unable to run "lsmod" (thought grubs zfs module might not have been loaded), returns unknown command
I am unable to run "search" as it also returns unknown command
Any help would be greatly appreciated.
markds
I should also add that I am able to run:"insmod zfs" without an error but unable to run "insmod boot" or "insmod normal" and hence unable to boot the system...
markds
Having tried all options I can think of in the grub rescue shell, I decided to download and use the iso to reattempt the upgrade again. Unfortunately after the upgrade process completed, the first reboot leads to the same grub rescue shell...
markds
for anyone else who had the same issue, I ended up overwriting my previous install with a new scale install and restoring a backup of core to the new install. now everything is working..
