grinding noise - HDD
Kennyvb8
Hello
i have 6 HDD in raidz1-0 i think, and last night one of the disks startet makeing grinding noises, and still doing.
Smart test shor/long all passes on all disks?!? so how do i figurer out which one is doing the noise? i have 2 new disks laying around i can easily replace 1-2 drives, but how to find the misterious one?
else i think i need to make som dd test in the zpool. and starting offline/online disks until it stops while standing next to the server?
Jailer
Not strong, but bad
kdragon75
Touch it, it's likely vibrating more than the others.
If that fails if you happen to have a friend or neighbor with a mechanics stethoscope that will do the trick to listen to each drive.
kdragon75
You can also use a long screw driver. Press you ear to the handel and the tip to the drive and apply a small amount of pressure. Works almost as well as a mech stethoscope.
Kennyvb8
Thanks a bunch, for all the answers!
i took a lucky attempt last night and marked a disk as offline and wham bam ! i found it! sadly i dont have any spare laying around so just orderet 2 new disk, 1 to replace and 1 for laying around :)
kdragon75
You don't say what drives your using but if there all the same model and one sounds bad, RMA/chuck it! With that said, some drives when the actuator (read/write arm) is working, sound like grinding gears... May be worl plugging the model into google to see if its a common complaint.
Kennyvb8
Just som random sata HDD. The one I turned off was a Samsung spinpoint running at 6.1 year online time 2 tb
Bought two ironwolf just waiting for them to arrive
