I just noticed by backup freenas machine is getting the following HDD alert messages:
I recently rebuilt the pool on this machine, it consists of 8 4TB seagate drives in raidz1 (I am aware that Z1 is not ideal but this is just a backup server running some of my older HDDs)
strangely when I run a zpool status command it says the pool is healthy and all disks are online?
https://pastebin.com/TwkU1Zmd
I also checked the smart info of ada6
https://pastebin.com/wpav8DsS
The drives have been is use for several years so the smart info is showing lots of old_age values but it seems to be online and passed the smart test so I'm not sure if it needs to be replaced or not.
the temperature is higher than i'd like at 44C but it does have 8 drives cramped into a tiny SilverStone DS380B case and freenas is not showing any high temp alerts so I don't think that is a huge issue.
Are thoughts on this? is the disk failing or not?
edit: How big of an issue is the 1168 Offline_Uncorrectable errors? the HDD still seems to be working and is passing the smart test despite these errors?
CRITICAL: Aug. 23, 2017, 2:57 p.m. - Device: /dev/ada6, 1168 Currently unreadable (pending) sectors CRITICAL: Aug. 23, 2017, 2:57 p.m. - Device: /dev/ada6, 1168 Offline uncorrectable sectors
