grade from SCALE 21.08-BETA.2 to TrueNAS-SCALE-22.02-RC.1destroys Apps
TheRichC
Grade from SCALE 21.08-BETA.2 to TrueNAS-SCALE-22.02-RC.1destroys
all installed Apps.
Of our 3 installs 2 survived the grade and 1 reports under Installed Applications,
"No applications are running". It lists no applications.
I can see the 3 images under Manage docker images, but all I seem to be able
to do there is delete them.
TheRichC
Restored config from backup that was saved before grade.. still no apps installed.
only option offered is to view catalog. it would appear that all containers
need to be setup again from scratch.
truecharts
It seems to be a UI mistake, please switch tab and they should re-appear.
TheRichC
Wish it was that simple. No amount of switching or refreshing shows the apps
and the apps are definitely not running. Would be nice if there was a config under the hood
I could tweak.
truecharts
If it's the red warning instead of the gray warning, your best solution is to file a Jira Ticket towards iX systems.
There is no magic pill for these issues and it's best to get them solved for everyone all at once ;-)
Trevor68
Yes, my apps were fine for weeks, but now all I get is the same red error
Trevor68
This just got much worse for me, cannot install apps now.
