I have used FreeNAS as primary system storage for many years, and I am so pleased with FreeNAS as a solution of storage, but recently I have updated my primary FreeNAS server, and I have experienced problems with one of my volumes. I hope you can help me because I have in this volume all my personal data.
I have updated from v9.10 U4 to v11.1 U1, and I have imported the volume with out errors, and since then I can see the zpool with the datasets in FreeNAS web GUI, and FreeNAS GUI shows disk used at 95% (Yes, I know, it is not recommended practice, but it was a temporary step to upgrade system). But when I try to share one of the datasets as a Samba Share, the GUI does not show the datasets to select one.
When I access in FreeNAS console I don’t see the dataset in /mnt/<volume name>.
I have other volume imported and I can see the datasets and information inside it.
What can I do? Should I update the dataset version? Or should I reinstall FreeNAS v9.10 U4 import this volume and copy all data in other disk and later install FreeNAS v11.1 U2?
More Info:
My System:
Xeon E5-2620 v4
Supermicro X10SRL-F
32 GB DDR4 ECC
IBM M1015 crossflashed to IT mode
The volume that gives problems is a RAID-1 (2 x 3TB WD RED NAS)
If you need more information as logs or execute some command, please ask for it.
More Info:
My System:
Xeon E5-2620 v4
Supermicro X10SRL-F
32 GB DDR4 ECC
