Dear Folks,
While awaiting the Big upcoming Truenas (whoop) I decided to double think about several aspects to understand it better.
1. User
Since truenas samba auth. is a new setting and enabled per default but ms.account is disabled per default. I was not able to understand the difference or impact of these settings ?
2. Dataset settings for smb (windows10 and macos clients)
So the recommended way (performance) seems to be smb and not generic, with the downside that it is tricky to use rsync and problematic with eg. syncthing inside of smb datasets. So I wonder if there is somewehere a comparsion pro&contra generic/smb options or Documentation about these settings ?
I do not need a complex acl structure for my shares - I just have a bunch of shares and I only need to restrict the users and groups on per shares basis and I struggled a lot in the close past with exotic behaviour eg. when acrobat reader comments a pdf which creats a undeletable tmp file (root/wheel) as well as libreoffice did things like that, etc.
Is there a simple way to create acls just on a share level but inside the share whithout acls at all ?
I don't know, I just think loud But I guess I'm not the only one.....
All the Best & Greets!
1. User
