Briefly the current setup I have is:
Asrock C2750D4I
crucial CT102472BD160B x 4 (32GB)
Thermaltake Toughpower Grand 650, 80+ GOLD
Fractal Define R4 , (bought additional front fan for 2 input , 1 output fan)
5 x 3TB WD reds
Basically i originally bought the C2750D4I a few weeks ago with the same ram, with a fractal node 804. After putting everything and after a few mins of running it powered off and would no longer get into UEFI bios. IPMI still worked but basically the main board was dead as far as i could tell, the asus logo would not even appear after powering on. I tried one ram stick at a time but nothing worked. so I returned both the board and ram just in case. Meanwhile i thought the node 804 is too small, so i also changed that for a define R4.
Then yesterday a got my new board and ram , (both from a different vendor than before). Now it boots fine every time but running anything (memtest86 for example) it will only run for about 2 mins and then just hang. IPMI still responds and I can see the hung screen from the monitor but the only action i can take is to power off and restart after which i get the same hang after a couple of minutes at most. The event log shows on two occasions it reported "FRB2/Hang in POST Failure" , which i dont see much information on online.
I tried removing and reseating all the ram to no avail. The only thing that hasn't been replaced (which im in process of replacing ) is the PSU (replacing with seasonic G series 550 ). The only other thing i can think of is that somehow the cpu is overheating because it doesnt have a dedicated fan? The manual says a cpu fan maybe needed if there is less than 2cfm airflow over the heatsink , but i dont really have a way to measure that. IPMI interace reports about 43C on the motherboard while it is on and i dont see anything in the event log regarding temperature events.
At this point im waiting for the new PSU which i will try and if that doesnt work I guess i will either give up on this board or try to RMA it for one last attempt.
Thanks for any advice /knowledge on this issue.
			Asrock C2750D4I
5 x 3TB WD reds
