I've recently installed running a freshly installed LAN only freenas 11.0 U3 and now I'd like to have a jail there.
During the setup phase I got an error that
I've provided it manually, which worked fine.
Now I'm stuck with
ssh to the box and create the not existing directory
Do you have a recommendation how to get the jail in place without opening the box to the outside?
Thanks and best regards!
Volk
.warden-files-cache/mtree is missing the file: freenas-standard-11.0-RELEASE.mtree
Now I'm stuck with
[warden_exception: http://download.freenas.org/jails/11/x64/freenas-standard-11.0-RELEASE.tgz: No address record ERROR: missing files cannot open 'data/jails/.warden-template-standard': dataset does not exist find: /mnt/data/jails/.warden-template-standard: No such file or directory ERROR: Failed to create ZFS base dataset ]
mkdir .warden-template-standard and providing the file didn't work. Do you have a recommendation how to get the jail in place without opening the box to the outside?
Volk
